Installing a set of med duty OME springs and I have a question about the metal bracket/rubber isolators that are on the original springs. Do you re-use those or install the new springs with them?
I have always heard that once U bolts are removed it is good practice to replace them. Don't know if that's an old wives tale or the gospel. When I installed my add a leafs to make my rear OME springs heavy's and compensate for the extra weight of the Dobinsons bumper I replaced the U bolts. Just made me feel better.Thanks!
I ended up reusing the bottom plat/rubber isolator and deleted the top plate. The old u bolts appeared to be too short with the top plate installed.
just finished the front. When I dropped the springs there was a 4ish degree shim/wedge between the spring and axel. As those standard? The funny thing is the far side of the shim was towards the front of the spring, shouldn’t it be on the backside of the axel to rotate the diff upwards to reduce the angle for the driveshaft?
Sorry for all the dumb questions but I’m a Cruiser noob.
