Maybe you're right. But nothing rusts here so that's a non-issue. and 4x4 Labs is 45 minutes away and has the reamers. Plus, I'd take the opportunity to ream for 1 ton ends.
You need to remember too, that the 80 box will only work on the later FJ60s and FJ62s, unless you rework the frame's bolt pattern.
@mcguirejohnson i think swapped in some skinny bolts on the offset corners and made a 80 box fit the early 60 bolt pattern, but I could be wrong.
