I replaced my flange gasket and closed up
my exhaust leak. The bolts were looking pretty rough so I picked up some new ones from ACE hardware (I’m guessing it may be a softer metal than OEM though). It’ll be good for a couple of days and then the bolts are gradually loosening and my leak comes back. I’m guessing they loosen from the constant heat expansion cycles of the exhaust. I think I’m going to pick up a set of OEM bolts from the Toyota dealer today. Can anyone recommend what I can put on them to keep them from backing out again? Most threads say to apply anti-seize but that seems like the opposite of my problem. The lock tights that I’ve seen isn’t rated past about 400 degrees. Any thoughts or recommendations?
