I'm trying to locate where the passenger side frame bracket should be located on the frame. The driver side had enough left I could get it located correctly, the passenger side just had welding scab left so I'm trying to get it located correctly. I have found some frame dimensions that show measurements but most would only help if I had a bare frame. I did find the measurement from the front body mount to the rear edge of the PS frame bracket but that's hard to get a good measurement as well. There is a hole in the top of the frame on the firewall side of where the bracket goes. maybe someone could help out with a measurement from center of that to center of the bracket? Other ideas are welcome. I plan on tacking these in, then bolting my 2F into the bell housing to verify fit before I weld them in for good. If nothing else I can just place that bracket then. Thx in advance for any ideas.
