FJ60 back spacing (1 Viewer)
Northern Virginia
I got an 87' FJ60 with 33x12.50/15 TSL's... someone told me the stock back spacing was 3.5 or 3.75, i was looking at black daytona steelies and they only come in 4'' back spacing, will that setup work?
thanks
-mark
[quote author=LuvenMud15 link=board=1;threadid=13912;start=msg129019#msg129019 date=1080604873]
thanks
-mark
[/quote]
It'll more in likely rub the calipers. I have a 60 with that exact same tire and 3.5" bs. IMO, 3" would be better as my tires rub the rear inner wheel well at full compression. The paints rubbed off a little in the back. I'll probably go with 2.5-3" bs next time.
Try Summit Racing, I have heard you can order just about any b/s on those same wheels from them. You may not be able to find it on their website, so I suggest calling them.
[quote author=Overlord link=board=1;threadid=13912;start=msg129021#msg129021 date=1080605133]
[/quote]
same here .. mine also rub the tie rod boots.... I think I'll get spacers like 1in to do the same thing as new wheels
I suggest that you consider a set of wheels with adequate backspacing for both the brake calipers and the width of tire you are running.
Stockton wheel will make a set of wheels wiith just what you need - for a reasonable price.
http://www.stocktonwheel.com/4wd_offroad.htm
Mike S
Yes, 6 on 5.5"
