fj60 4sp transmission front seal leaking
hward1
87 fj60 / 95 fjz80
CA for little while
87 fj60 4sp was wondering to change out the front trasmission seal do you have to drop the transmission -- :rolleyes:
Yes. The input shaft seal and the front bearing retainer gasket.
You have to pull the transmission. Then take the seven bolts out. I used Permatex Black lightly on both sides of the paper gasket and some on the bolt threads. The input shaft seal is just a direct swap. No sealant or anything.
HTH
