looking for input fellas:
Build specs are as follows:
4.8 Chevy LS motor
NFW 1040 Flywheel
LUK 04-048 Clutch
Speedway 91025610 "Stock GM Hydraulic Throwout Bearing"
Ranger Overdrive (Chevy to Toyota 4sp ) same spec as SM465 on the GM end.
Stock 4sp transmission.
During install, followed to intall directions on figuring spacing so I thought I was good to go. Fired up the truck and put it gear to check clutch engagement and nothing. Looked for airgap at front if bearing, and there was none. Pulled the motor away from trans and discovered the inner sleeve of the bearing was chewed to s***.
Thoughts and input much apreciated.
4.8 Chevy LS motor
NFW 1040 Flywheel
LUK 04-048 Clutch
