Hello everyone.
I'm chasing a drivetrain whine on my FJ60. Tomorrow I'm going to get the truck up on the lift and start exploration, because everything I've tried so far has had no luck. But I wanted to ask in case my symptoms are identifiable to someone with more knowledge than I have.
The truck is an '85, running a 6.0 vortec and a built 4L65E that I purchased as a freshly rebuilt unit from a shop that specializes in them.
I have the factory transfer case, which I did a total rebuild on, following the FSM, and finished the job with no hiccups and nothing seeming out of place.
Symptom:
The truck begins to whine somewhere between 20-30mph, and the whine is high pitched. It grows higher and louder with speed, and to my ears, sounds like a gear whine, but what do I know?
The whine is only under load - acceleration and deceleration. Under a steady cruise with minimal throttle it tends to fade away. The whine will also disappear if I shift into neutral while driving.
The sound does not "shift" with the transmission. It's a completely linear sound.
I assume it must be the transmission, the transfer case, the rear driveshaft, or the rear diff.
I never drove the truck before the swap, as I bought it not running.
I assume it's not the diff, as the sound seems to be coming from around the shifters, but anything is possible.
Do these symptoms sound familiar to anyone else? Gut instinct tells me it must be the transfer case, since I did the work on it.
I've checked my fluids in both the transmission and the transfer case and they're both full with brand new fluid.
I used 75w90 in the transfer case.
I greased the zerks on the driveshaft.
So far, no luck.
Any other tips, tricks, or things to look for so I'm not going in blind?
Thanks as always.
Mike
Symptom:
So far, no luck.
Thanks as always.
Mike
