Fj60 1982 2F, High Flow thermostat & Thermostat Housing Bolts question, (2 Viewers)
ToyotMatt, I cant' find the studs on your website, i found the cadmium bolts which are better on aluminum and SS as well, but no studs.
Do you have a link? I was about to kick it off..
No need for the hi-flow T-stat, but whatever you do, make sure you install the o-ring on top of the t-stat. If it's not there, you will never get up to temp.
I personally would think to use copper anti seize in this application ?
Not a bad idea, but there is no reason not to use the silver grade. Depending on which version you use, the copper has a slightly higher operating temp, but we are talking 1,800 not 210 deg..
