- Thread starter
- #181
Got the turbo side done today. That G turbo looks sweet!
Yeah that's the plan .I would recommend an upgrade to 80 series booster and master if you have things open!
Great work btw.
Yeah, you can pull it with the front ac core and cross member with the right equipment and if you leave the bellhousing on the transmission. It will be going back in with the bell attached. It's a pita, I'll probably pull all that out to put it in though cause the bell is on. I have a hoist lever, I may try and see if I can snake it in. Hood was removed also, it was bolted on after it go pulled.@MCJakeCrim: It looks like you pulled the 12HT without taking off the front end (radiator, etc.) and without disconnecting the AC stuff. Is that correct? If so, how did you do that?
And were you able to pull it without taking off the hood? Or did you just put the hood back on after cleaning the engine bay?
Great job, by the way. Everything looks absolutely fantastic. How many hours do you think you have in it so far?
-Sean
It took me about 30 hours of work to actually put the engine together. I have about 100 hours just in cleaning and ceramic coating all the parts. What's time consuming is parts, ordering and waiting for the right parts.@MCJakeCrim: It looks like you pulled the 12HT without taking off the front end (radiator, etc.) and without disconnecting the AC stuff. Is that correct? If so, how did you do that?
-Sean
Thanks for the replies. I do not see a before cleaning picture attached. Can you repost?Heres a comparison pic to before cleaninng
Yeah, I cant seem to find the before pics. I may have accidentally deleted them. Attached is an older pic with it in.Thanks for the replies. I do not see a before cleaning picture attached. Can you repost?
Thanks!
Dayum - that looks greatGlow screen was replaced by a CNC water-jetted block of aluminum. Vsv has been replaced by a 3 inch throttle body. More airflowView attachment 2093282View attachment 2093284.
I spent a day cleaning out the engine bay too. It was a greasy mess. View attachment 2093289View attachment 2093290View attachment 2093291
