Hey everyone. I’m going to attempt my first oil pan gasket replacement this weekend. I have never done one so any advice or tips would be appreciated. i have watched a few videos and it seems to be straight forward: drain oil, replace oil filter, remove pan, clean old gasket from block and pan, I plan to clean and repaint pan at this time also, replace gasket, torque bolts in cross pattern to factory specs….
Do I need to go ahead and replace the oil pump? I believe their is an in pan one correct?
Do need to apply a special sealer to the gasket prior to reinstalling the pan?
Are there any other gaskets that should be or would be easier to replace with the oil pan off if I am already under there?
