I have a Dec. 71 FJ55. Some time ago the fuel tank developed a vacuum that caused the tank to collapse inward from the top. A shop dropped the tank and pressurized it and managed to make it less concave but it still is caved in a bit. The problem I have now is when I go to fill it up, the vent tube in the inside of the tank is submerged with about 5 gallons left to fill so it takes quite some time to fill the last 5 gallons, otherwise I risk spilling gas. My question is, can I switch the vent tube hose with an evaporative emission hose? I can't really see where the evaporative emissions tubes end up inside the tank, does anyone know if they stay at the top or do they bend down towards the bottom of the tank? If all these tubes end as an open line in the tank, I'm assuming it's safe to switch them around, might that not be the case? The evap tubes are probably 1/3 the diameter of the vent tube, if I did switch one, would it not vent quickly enough so I just end up with the same problem in the end?
Thank you,
Brian
Thank you,
Brian
