FJ55 Carb question
Discussion in '40- & 55-Series Tech' started by eddybear, Feb 27, 2004.
  1. eddybear
    eddybear
    33
    Feb 27, 2004
    Wilmington, NC
    Need a new carb for my 1972 FJ55. SOR has a rebuilt factory one for $425. Autozone has 3 Aisins, one by FC, one by Champion. and one by Tomco, for between $160 to $230 w/ a core value of $25-$65. Seems like a big difference in price for the SOR factory, tho I have had good luck dealing w/ them. Do the Aisin's require any modifications? Would appreciate any insights. Thanks!
    Ed
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    Do you know what is wrong with your current carb, specifically?
    Jim C. is very knowledgeable on the factory carbs. I would contact him about your situation, before I spend monies on any of these options you have presented.
    Good luck!
    -Steve
    Jim Chenoweth
    TLC Performance
    Lancaster, Ohio, USA
    Ph. 740.862.2604
    TLCA #1914
  3. RHINO
    RHINO
    3,764
    3
    Dec 23, 2003
    valley of the sunstroke, AZ
    the aisin IS a factory carb, its what you should have now, its also what SOR has, the three autozone has are factory aisins but those names are the rebuilders, FC, champion ect.. they could be cheap rebuilds i dont know.
    i second Jim C. he is good.
  4. eddybear
    eddybear
    33
    Feb 27, 2004
    Wilmington, NC
    The Toyota tech tells me the current carb is a totally shot one barrel and that the replacement needs to be a 2 barrel....sound correct on the number of barrels? If I get a non-USA carb do I need to modify the distributor or will it work with the stock one? I have read of non-USA distributors and wonder if I would need one of them as well.
  5. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    24
    Jan 3, 2003
    McCall, ID
    The nonUSA carbs are made to work without all of the smog stuff, and with a vacuum advance dizzy. The nonUSA dizzy is a vacuum advance type. I believe your 1972 dizzy is a vacuum advance like my old one was in my 1971. Someone correct me if I am wrong on that. So. It should work. That being said, the nonUSA dizzy is slightly different from the stock USA, and is presumably going to be a little better quality. IF you have the bucks, you won't be disappointed having a new, unworn distributor in there.
  6. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    24
    Jan 3, 2003
    McCall, ID
    And yes, you should have a 2 barrel in your 72 for sure.
  7. Landpimp
    Landpimp GOLD Star
    15,856
    Media:
    1
    1,895
    Mar 14, 2003
    Gig Harbor WA
    can I have your shot old Aisin barrel? ya can't get parts for em and I would like to have a spare float.
    FWIW your 72 should have had a 2 barell on it when new, 68 was the last year for the 1 barrel
  8. eddybear
    eddybear
    33
    Feb 27, 2004
    Wilmington, NC
    The old carb was traded for some minor bodywork. Sorry :(
