FJ45LV window gaskets
Columbia, MO
Website
www.tornadoalleycruisers.com
Anyone got good part numbers or substitutes for front windshield, long side windows, and rear lift gate glass? I'm gonna need them in about 8-10 weeks:)
chef
I'm kinda in the same boat, might be a little sooner time frame, but in that ball park.
Foxfab, when you say, "gasket and key", do you mean the gasket has another piece that fits in after install?
Thanks, Matt
Chef, I pm'd you before I saw this thread, but I'll repeat some info here for the others. Yes the SOR early FJ40 windshield gasket with the key works for all 3 pieces of cargo glass, as well as the windshield. However, The glass size will have to change with this gasket. With the original gasket, the glass sat in front of the metal flange of the window openning and hung passed it. With the new gasket, the glass sits directly in line with the flange and thus, has to be smaller in size. To get a pattern for the new glass size, trace the window openning at the flange onto a piece of paper and move that line towards the center of the window 1/4" all the way around. Cut the gasket down to size by first making a cut all the way through, then wrap it around the glass and make it about 3/4" longer. This will help in not having a gap at the new seam. Always put the seam at the top and fill with a black caulking. Only other thing I would suggest is put the key on the inside. This will give the outside a more "original" look and is better for security.
Junky;
Great post...and fershure the front windshiled gasket will work for side windos and rear gate? That seems nice and easy:)
thanks for the post!
Chef said:
Junky;
Allan, I'll let you know for sure hopefully in a few days. I just got 4 windshield gaskets and keys today from SOR :) . Hoping to get installed in the next couple days. Ordered them specificly because of Junky's post.
Matt
Land Cruiser Junky said:
Always put the seam at the top and fill with a black caulking. QUOTE]
Question, why do you want the seam at the top and not at the bottom? Just curious?
Thanks, Matt
Yeah, water actually collects between the glass and the rubber at the bottom and if the seam is not seal, will just pour down the dash. The same thing will happen at the top if the seam isn't sealed, it's just a much smaller flow.
The SOR part # is 120-03B/A-A/108. I can't remember if this part is aftermarket or OEM, but looking at it I'd say OEM. It's great quality stuff. And yes the glass size is going to be smaller because the FJ40 rubber is nothing like the shape of original LV rubber. I don't have the part # for the key right now, 'cause I can't find the two that are in my garage. Just tell them you need the key that goes with this rubber.
