fj45lv Proper Caster?
St. Louis
Anyone have suggestions on what the caster should be for an lv? Just had an alignment and came out with +1.5 and +1.6. Old timer at the alignment shop adjusted toe in and it wanders a lot less now, but thinks I should shim it to +3.0. I've got 33 inch tires and OME springs. I just want it to track a little straighter. And if I put a +1.5 shim on it, will that screw up my pinion angle? I really don't want to cut and turn, it's not that bad, but if there's an easy fix, I'd like to try it. Thoughts? And in case its not obvious, I'm a newbie to this.
Take it back to TLC4x4 and tell them to set it up right ;)
Do a search in the 40-55 tech, read up on it in the tech section (Andre aka, dieselcruiserhead's write-up is a good start)
I think you should have around +3 deg to +5 deg. I think I put +7 or +9 on my SOA. Each vehicle will be different though.
You can buy those shims and slap them in pretty easily. Drive it and see if that does the trick.
Good luck.
Tom wood's has steel shims, I picked some up at Moab this past year. You'll possibly need new spring centerpins to fit thru the shim and axle hanger. Feel free to holler in the TornadoAlley section if you need help.. We've got guys somewhat close and I'll be in St Louis next month for a work trip and to test fit some 38"s on a buddy's Fj40 and pick up the roof for my FJ45..
1.5* isn't gonna mess up your pinion angle.. YOur not gonna be running around in 4wd all that much. I added like 8* shims on my FJ40 and still wheel it! It didn't fix my problem but mine's much more severe on my Fj40 than a little wandering :)
Thanks for the feed back. Dan, if I weren't so far away I think Jonathan would probably do it for me. I feel like he just did a heart-lung transplant on a dying patient, so I don't want to sound like I'm complaining about an ingrown toenail. It's much better than when you drove it, but I still want to dial it in. tornadoalley give me a yell if you have time when you're in town.
From the FSM, 1964.
Castor "should" be 1 degree.
