FJ45 gas tank repair
Discussion in '40- & 55-Series Tech' started by FJ60, Feb 23, 2004.
  1. FJ60
    FJ60
    270
    Jun 27, 2002
    after pulling a rather large piece of shag carpet from under the gas tank in my FJ45 I THOUGHT I had done a good thing preventing moisture and further rusting. Apparently the carpet was absorbing the fuel from the leak in the tank and I just THOUGHT it smelled like fuel before :D now it's unbearable.
    Should I clean and try to reline my old tank??? I'm fairly sure I wont find a factory replacement for my 1967 Fj45...
    questions, comments and smart ass remarks accepted :D
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
  3. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    There's nothing for it but to give me your truck and I'll deal with it.
    No, really, you could try the POR 15/American standard or whatever brand it is reliner. Or you could have it relined at a radiator shop for twice as much money. Or call the tech line at SOR and ask them what fits. The carpet may have been there to reduce vibration and consequent wear on the tank metal, and not just to absorb gas.
  4. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    I'm thinking Dave's right about the carpet, as the PO prolly had a leak earlier. If it's some minor pitting, I've used Marine Tex and it's worked well long term. Make sure you wire brush out the leaky area well first.
  5. FJ60
    FJ60
    270
    Jun 27, 2002
    I went through the yellow pages looking for someone to do my FJ40 tank about a year ago and finally gave up and patched the tank.
    I thought the fuel smell was from the old seats but now I have fuel in the passenger floor ::) so I'm hoping to repair this somehow when I run the rest of the gas out.
    I was having trouble with the altenator and P.S. pump too and best I can tell they both need replaced :p (alt. not charging - p.s. groaning to high heaven).
  6. Landpimp
    Landpimp GOLD Star
    15,929
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    I'll take a look at my 45 and 65 fj40 to see if the tanks are the same or if I think they would swap...........but for some reason I think the 45 tank is a 45 tank..........not sure why
  7. FJ60
    FJ60
    270
    Jun 27, 2002
    the top looks just like the Fj40 tank but I believe it's alot deeper and shaped to fit into the recess under the seat. I had considered a fuel cell but have no plans yet :p
  8. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    I am fairly certain that the FJ45 gas tank is different from the FJ40 also. No first hand knowledge, but from what I have seen in pictures.
    Also, SOR's fuel tank page has this entry, below all of the FJ40 tank listings:
    FJ45PU GASTANK----(Discontinued-No longer available) 0.00 No
  9. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    23
    Jan 22, 2003
    Kansastitty
    At this point, you might as well try to line it. Remove the sender unit and put some CLR in it along with a piece of chain. Rattle that around in there to get all the scale out of it, most will be in the bottom, where the water was. Then take it to a carwash and blast it out as best you can, let it dry and follow the instructions on the POR product. If you end up with more than a pinhole, you can patch it from the outside with a fuel resistant epoxy, then line it. The tank should be reinstalled with some rubber supports underneath it, I used pieces of mudflap and some trim cement to hold them in place while reinstalling. It has worked so far.
    GL :)
    Ed
  10. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    The rubber supports reduce the electrolysis induced oxidation of the metal of the tank by insulation. Rubber works better than water soaked carpet for this purpose.
    :D
  11. Poser
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    [quote author=Landpimp link=board=1;threadid=11955;start=msg109079#msg109079 date=1077563889]
    [/quote]
    Becasue you are probably correct....I will look and measure when I get to the shop Tues. AM, and see what I find...For some reason, I thought that someone I ran with once in NM had installed a 40 tank in his 66-45 LWB pickup because of the tank rotting out...
  12. FJ60
    FJ60
    270
    Jun 27, 2002
    [/quote]
    WELL!
    :D
  13. red66toy
    red66toy dorkus malorkus GOLD Star
    2,360
    1,104
    Feb 25, 2003
    Seattle, WA
    Semi Hijack
    How thick of rubber pads do you guys use under you gas tanks? Thanks.
  14. Poser
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    1/4-3/8"
    belting from an ag dealer works well...
  15. red66toy
    2,360
    1,104
    Feb 25, 2003
    Seattle, WA
    wow, thanks for the help and the quick reply. :)
  16. Poser
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    [quote author=Deep South Cruisers link=board=1;threadid=11955;start=msg109597#msg109597 date=1077646180]
    WELL!
    [/quote]
    The two tanks, while looking similar are different. Your best bet would be to have yours repaired. I have had this done to a few tanks at a radiator shop. Sorry for propogating misinformation....
  17. pygpen
    pygpen
    472
    1
    Dec 9, 2002
    Benicia, California
    I'll second that ;)
    I have a 65 FJ40 and a 65 FJ45. The tank from the 40 would not fit the 45 due to the rear seam IIRC. Call radiator shops about boiling it out and repairing it.
    PMK
  18. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    23
    Jan 22, 2003
    Kansastitty
    IIRC, they don't "boil" it out because the caustic removes the zinc coating that is supposed to prevent rust. My shop steam cleaned mine and used a POR type liner in it, seem so far...so good. I think they ripped me though...$80.
    Ed
  19. Poser
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    Did you have to do anything other than bring them the tank Ed?
  20. cdv3286
    cdv3286
    97
    Jul 27, 2006
    Fayetteville, NC
    What do you guys mean by lining the tank?
