That's the problem with the youth these days. They procrastinate, then always forget something at the last minute. But you are in luck, I didn't use the ones that came with my kit. If you would have mentioned this earlier, I could have dropped them off with the seals. I can leave the here tommorow and you can pick them up when you want. Fix that thing and
Then of course sometimes you refuse to think as you start getting older. If the shims already in there aren't f'd up, can't you reuse them. you already have the thickness you need. I used my old ones and got the right tension (via fish scale method).Does anyone have the shims that work with the knuckles?
I would like to give a big thanks to everyone who has able to show up or helped with parts. (Rudy, Jon, Daisy, Jarred, Andrew, Chris, and Ali) My 2.5 OME lift looks great. I couldn't have asked for a better group of guys to have help me. For everyone who was able to make it my father also sends his thanks and regards; he was unable to make it because of a work conflict, but he hopes to see you guys soon. Thanks for all the help. This goes for anybody in the club after next friday my father and I are free for two weeks before we both start up school again, so if anybody needs help let us know.
Thanks a ton,
Paul and Cy
Needo picturo
Dan
You are missing something! Finish the phrase, "This Thead is worthless without _________"
Make sure you bring the extra shims, even if you don't need them. Also, since you are up in that neck of the woods, you should have Diesel Dan do an expert rebuild of your Aisins....
I also have a set of Aisins that I snagged from a junkyard, that I need Dan to look at them so I know what to get to finish them out.Pauls hubs are Warn.
Looks good! Gives it a nice proud stance!
Jarred
