The "link" is the bar between the to wiper arm studs.I did all that. The worm drive shaft is still attached to the wiper linkage. What is this link they are talking about and how is it removed? I see no obvious way without a special puller to remove the linkage arm that is press fit onto to drive shaft spline.
Thanks all. The pry bar worked. Not knowing that the ball just popped out of the socket, I didn’t want to use too much force.Thanks for the responses. That helps. I'll give that a try.
