- Location
- United States
FJ40 stock steel wheels '74 or later Wanted: 4 or 5 stock steelies in good or restored condition, preferrably with hubcaps if you've got them. 15" x 5.5", welded rims not riveted. Please let me know what you've got.
I also need a parking brake drum from a 4 speed transfer case to match to the larger yoke '74 & up U-joint flanges. Bolt centers 60mm x 68mm. This is going on a 3 speed transfer case w 10 spline output shaft (should be the same as the 4 speed transfer case output shaft). The smaller bolt pattern on the older brake drum does not match my drive shaft.
I am located in East Tennessee. Thanks.
