Getting it together for sniper install on 77 FJ40 w/ orig 2F. Ive searched the forum and it seems the best way to go will be AC delco vacuum canister, routing one line to base of sniper vacuum , with the vacuum modulator in between to control the flow, with a “T“ off the distributor advance vacuum line to activate the modulator.
Here’s my question: I can’t seem to source the AC Delco 214-552 modulator that I’ve seen used on other builds. Is there an alternative that will work for this? I can wait and keep checking online but if theres an acceptable alternative I’ll get that . I thought you all would know.
Also, I want to make sure I get the right AC delco vacuum canister for this task. I’m concerned my OEM canister is not going to be as functional . Can someone link the part number for the right AC delco vacuum canister? Thanks in advance.
