FJ40 Rear tailgate weather stripping
Content may include affiliate links. Please see terms for details.
Qld, Australia
Looking for some alternatives for the rear tailgate doors on my 71 FJ40, the old ones are worn and hard to get a correct measurement from but in seems they are 9mm wide and 4mm thick. It comes up in a search on mud as a possible new one piece strip but lists 5 seperate pieces in the Toyota parts catalogue?
The one piece would cost around $100 and l would potentially need two, one for each side.So looking to see what others have used, found a EPDM sponge strip that measures 10mm wide by 4.5 thick and at $2.70/m am considering trying it.
Amarillo Tx.
This is what I use in a pinch, literally...
Its simply 2 small bulbs that you can easily cut or even tear down the middle. Cheap and you can find it at most Lowes, Ace, Home Depot or the like. Clean the surface with some denatured alcohol and trim to fit. 1 :banana: job.
Amazon product
John McVicker
Big Pine, CA
@POTATO LAUNCHER AND I just used some of this to help put an airtight seal around the top of my new radiator. Good stuff & easy to work with.
