I'm thinking of swapping my FJ40 transfer case for a NP205 that I've had laying around. That means I need a centered differential for my '73 FJ40.
Does anyone out there have a recommendation for what axle might be best?
I'm currently running 1.25" spacers on the rear. I haven't pulled the wheels to measure the backing plate to backing plate width but found on line that it should measure 55" without spacers, so the axle width with spacers should be 57.5". I'm thinking anywhere from 55" to 58" backing plate to backing plate would work.
Has anyone out there done an axle swap and if so, what worked for you?
