Wanted FJ40 Power Steering Pressure Hose NON-US (1 Viewer)
Roswell GA
Like the title says, ISO high pressure power steering hose for the gear side of a non-us 1982 FJ40. Picture is for reference, possible part numbers are 4441160080 or 4441160090. The hose has a male fitting on the side that connects to the steering box and a female side that connects to the hard line.
It's my daily driver so I don't currently have the option of pulling the hose and finding someone to build a new one. Even if you have a used one I can get rebuilt that would work, I just need a vehicle daily to drive.
Thank in advance!
Kelly
I have this kelly
it can be made easy to work and. Meet your needs
it’s a nos oem
Toyota part from another toyota Vehical aplocation
same threaded fittings and tubessize too just likeyour non USA 40 series
I have used this same part # to get it done on both a USA spec and non USA same as you have application more then once
Let me know know I can help
PM me to further discuss
this is a high pressure and low returns together FYI but they separate via the brackets bolted to tabs
@ToyotaMatt , PS gearbox side of the part pictured looks like it will work; however, the other end will need to be modified for the hard lines that run to the right side of the engine. Here’s a picture of the hard lines I’m referring to (PN 44413 in the diagram above):
since your a Fellow maryland'r You can simply have this NOS hose set , NO cost involved if you can use it to help get your truck back
on the road ................. :D
Let me know how i can further help ........
MUD-SHIP SATURDAY !
Oh man! I always enjoy free! I was planning on reaching out to place an order after another Maryland’r @Blue77FJ40 mentioned you were local.
I’m currently rebuilding an FJ62 ps pump to be used for my 3B. I have the high pressure line that runs from the pump to the hard line on the passenger’s side.
I’m in a similar situation as the OP regarding the high pressure line on the gearbox side. I may be able to bend the hard lines of the setup you posted. I’d still need to find the correct tube nut to replace the banjo fitting on the other end. So, I’d need to find a hydraulic shop that can swap that side out.
I’ll be in touch regarding the lines. I had a short list of things I was planning on contacting you about anyway. Thanks
Your welcome
let me know how I can further help
Matt
Thank in advance!
Kelly
In addition to the NOS double lines set up above ..........
I also have these going on too , i just remembered there my climate controlled out building
or
my fenced UNICORN pasture :D
I noticed at the end of the outer bubble flare, there’s an inner flare and o-ring. Is this a replaceable item?
@ToyotaMatt just sent/paid for an order through www.vintageteqparts.com for a few items. I had intended to reach out for some assistance with plumbing & wiring up my factory AC setup when I get to that point. I’m missing:
These pictures were pulled from a 2B setup.
The truck didn’t have OEM AC. So, something comparable that would substitute would be fine.
I think this part is specific to diesel models. This hose and sensor connect to the dryer.
YES
the o-ring is replaceable
