ksemerdjian
Email sent.
Content may include affiliate links. Please see terms for details.
No worriesMy bad!
Item Description | Ship/No Ship | Cost |
bell housing inspection cover | Ship | 25 |
battery tray support | Ship | 25 |
radiator support short | Ship | 10 |
radator support long | Ship | 15 |
water pump pulley 2 groove | Ship | 20 |
water pump pulley single groove | Ship | 20 |
Ship | 10 | |
heater vent cable pull | Ship | 25 |
Ship | 50 | |
Power steering bracket | Ship | 50 |
Gauge Cluster Bezel New | Ship | 35 |
hard top L bracket set of 2 | Ship | 20 |
Ashtray no door | Ship | 20 |
Ship | 30 | |
Hood catches set of 2 | Ship | 20 |
t-case linkage and brackets | Ship | 25 |
shifter knob black | Ship | 10 |
wiper arms with blade set of 2 | Ship | 20 |
wiper arms no blade set of 2 | Ship | 15 |
radiator cap new | Ship | 10 |
wheel cylinder kit 04311-60021 | Ship | 10 |
cylinder kit 04471-35014 | Ship | 10 |
fuel filler housing | Ship | 25 |
Ship | 25 | |
Ship | 40 | |
Ship | 25 | |
bag of round body mounts(9) + bolts | Ship | 20 |
Ship | 50 | |
ebrake lever assembly | Ship | 50 |
window wing green | Ship | 30 |
window wing red | Ship | 20 |
clutch pedal | Ship | 20 |
horns smaller style (3) | Ship | 10 each |
window regulator grey | Ship | 10 |
window regulator red pair | Ship | 20 |
turn signal rod | Ship | 15 |
kick vent green | Ship | 15 |
kIck vent red pair | Ship | 20 |
Ship | 15 | |
Ship | 10 each | |
spare tire wrench toyota stamping | Ship | 20 |
clutch master cylinder used | Ship | 10 |
clutch slave cylinder used | Ship | 10 |
Ship | 50 | |
heater blower | Ship | 25 |
blower ducting | Ship | 15 |
blower ducting rubber | Ship | 10 |
shift boot w/ring and inner sleeve | Ship | 35 |
tcase boot w/ring and inner sleeve | Ship | 35 |
shift boot w/ring older type | Ship | 15 |
shift boot no ring | Ship | 10 |
rearview mirror | Ship | 15 |
door inspection plate pair | Ship | 20 |
inner door latches (2) | Ship | 10 each |
exterior door handles (5) | Ship | 5 each |
Ship | 25 | |
steering column bracket | Ship | 10 |
steering column bracket with rubber | Ship | 15 |
Ship | 25 | |
BTB fuse box mount NEW | Ship | 25 |
lift hatch cover grey | Ship | 35 |
lift hatch cover tan | Ship | 75 |
gas pedal | Ship | 10 |
fuel line filter | Ship | 10 |
oil cooler hose NEW 15779-61010 | Ship | 20 |
78 dizzy with caps and parts | Ship | 100 |
FST glass retainer NEW pair | Ship | 20 |
bump stops pair | Ship | 10 |
vent cable pull mount (2) | Ship | 10 each |
top window felt NEW 68212-90300 | Ship | 5 |
wiper arm inserts set of 2 | Ship | 15 |
brake lines 10" NEW | Ship | 10 each |
apron weatherstrip (3) | Ship | 5 each |
door locks (2) | Ship | 5 each |
rear hatch door locks (2) | Ship | 5 each |
brake pedal rubber pad NEW | Ship | 5 |
windshield vent WS used | Ship | 5 |
windshield cowl WS used | Ship | 5 |
Ship | 10 | |
kick vent WS pair one new one used | Ship | 5 |
output flange course spline | Ship | 10 |
output flange fine spline | Ship | 10 |
pile of used roof WS | Ship | 20 |
window wing mounts set of 2 | Ship | 20 |
reverse light cover | Ship | 5 |
hood rubber cushion set 51464-90800 | Ship | 15 |
hood hinge pad set of 4 NEW | Ship | 10 |
hinge pin and bushing set | Ship | 10 |
footman loop chrome (12) | Ship | 2 each |
footman loop grey (2) | Ship | 1 each |
footman loop 133-30 NEW (4) | Ship | 2 each |
Ship | 25 each | |
vacuum hose kit 04000-11120 NEW | Ship | 10 each |
inner door striker (4) | Ship | 5 each |
Ship | 5 each | |
Ship | 1 each | |
wiper nut | Ship | 5 |
horn relay used | Ship | 10 |
FJ40 side dome light | Ship | 15 |
side markers red (3) | Ship | 10 each |
side marker housing (2) | Ship | 5 each |
Ship | 15 | |
wiper switch | Ship | 15 |
ignition switch with key | Ship | 15 |
heater switch | Ship | 15 |
cig lighter housing | Ship | 5 |
fuse holder | Ship | 5 |
parking light housing round (2) | Ship | 5 each |
Ship | 20 | |
Telescoping mirrors pair | Ship | 75 |
Ship | 10 |
Here is the list updated. If there is a line thru the item, then it is sold.
Item Description Ship/No Ship Cost bell housing inspection cover Ship 25 battery tray support Ship 25 radiator support short Ship 10 radiator support short Ship 10 radator support long Ship 15 water pump pulley 2 groove Ship 20 water pump pulley single groove Ship 20 hood prop short styleShip 10 heater vent cable pull Ship 25 motor mounts pair newShip 50 Power steering bracket Ship 50 Gauge Cluster Bezel New Ship 35 hard top L bracket set of 2 Ship 20 Ashtray no door Ship 20 AshtrayShip 30 Hood catches set of 2 Ship 20 t-case linkage and brackets Ship 25 shifter knob black Ship 10 wiper arms with blade set of 2 Ship 20 wiper arms no blade set of 2 Ship 15 radiator cap new Ship 10 wheel cylinder kit 04311-60021 Ship 10 cylinder kit 04471-35014 Ship 10 fuel filler housing Ship 25 fuel filler neckShip 25 clutch master cylinder newShip 40 clutch slave cylinder newShip 25 bag of round body mounts(9) + bolts Ship 20 superwinch locking hubs pairShip 50 ebrake lever assembly Ship 50 window wing green Ship 30 window wing red Ship 20 clutch pedal Ship 20 horns smaller style (3) Ship 10 each window regulator grey Ship 10 window regulator red pair Ship 20 turn signal rod Ship 15 kick vent green Ship 15 kIck vent red pair Ship 20 bottle jack bracketShip 15 door hinges (5)Ship 10 each spare tire wrench toyota stamping Ship 20 spare tire wrench toyota stamping Ship 20 clutch master cylinder used Ship 10 clutch slave cylinder used Ship 10 heaterShip 50 heater blower Ship 25 blower ducting Ship 15 blower ducting rubber Ship 10 shift boot w/ring and inner sleeve Ship 35 tcase boot w/ring and inner sleeve Ship 35 shift boot w/ring older type Ship 15 shift boot no ring Ship 10 rearview mirror Ship 15 door inspection plate pair Ship 20 inner door latches (2) Ship 10 each exterior door handles (5) Ship 5 each apron emblems with hardware pairShip 25 steering column bracket Ship 10 steering column bracket with rubber Ship 15 BTB battery tray NEWShip 25 BTB fuse box mount NEW Ship 25 lift hatch cover grey Ship 35 lift hatch cover tan Ship 75 gas pedal Ship 10 fuel line filter Ship 10 oil cooler hose NEW 15779-61010 Ship 20 78 dizzy with caps and parts Ship 100 FST glass retainer NEW pair Ship 20 bump stops pair Ship 10 vent cable pull mount (2) Ship 10 each top window felt NEW 68212-90300 Ship 5 wiper arm inserts set of 2 Ship 15 brake lines 10" NEW Ship 10 each apron weatherstrip (3) Ship 5 each door locks (2) Ship 5 each rear hatch door locks (2) Ship 5 each brake pedal rubber pad NEW Ship 5 windshield vent WS used Ship 5 windshield cowl WS used Ship 5 steering wheel firewall mount coverShip 10 kick vent WS pair one new one used Ship 5 output flange course spline Ship 10 output flange fine spline Ship 10 pile of used roof WS Ship 20 window wing mounts set of 2 Ship 20 reverse light cover Ship 5 hood rubber cushion set 51464-90800 Ship 15 hood hinge pad set of 4 NEW Ship 10 hinge pin and bushing set Ship 10 footman loop chrome (12) Ship 2 each footman loop grey (2) Ship 1 each footman loop 133-30 NEW (4) Ship 2 each door weatherstrip NEW (2)Ship 25 each vacuum hose kit 04000-11120 NEW Ship 10 each inner door striker (4) Ship 5 each door limiters aftermarket (2)Ship 5 each door hinge pins (8)Ship 1 each wiper nut Ship 5 horn relay used Ship 10 FJ40 side dome light Ship 15 side markers red (3) Ship 10 each side marker housing (2) Ship 5 each license plate lightShip 15 wiper switch Ship 15 ignition switch with key Ship 15 heater switch Ship 15 cig lighter housing Ship 5 fuse holder Ship 5 parking light housing round (2) Ship 5 each bumper hooks pairShip 20 Telescoping mirrors pair Ship 75 bumpers withThanks
Email sent.Here is the list updated. If there is a line thru the item, then it is sold.
Item Description Ship/No Ship Cost bell housing inspection cover Ship 25 battery tray support Ship 25 radiator support short Ship 10 radiator support short Ship 10 radator support long Ship 15 water pump pulley 2 groove Ship 20 water pump pulley single groove Ship 20 hood prop short styleShip 10 heater vent cable pull Ship 25 motor mounts pair newShip 50 Power steering bracket Ship 50 Gauge Cluster Bezel New Ship 35 hard top L bracket set of 2 Ship 20 Ashtray no door Ship 20 AshtrayShip 30 Hood catches set of 2 Ship 20 t-case linkage and brackets Ship 25 shifter knob black Ship 10 wiper arms with blade set of 2 Ship 20 wiper arms no blade set of 2 Ship 15 radiator cap new Ship 10 wheel cylinder kit 04311-60021 Ship 10 cylinder kit 04471-35014 Ship 10 fuel filler housing Ship 25 fuel filler neckShip 25 clutch master cylinder newShip 40 clutch slave cylinder newShip 25 bag of round body mounts(9) + bolts Ship 20 superwinch locking hubs pairShip 50 ebrake lever assembly Ship 50 window wing green Ship 30 window wing red Ship 20 clutch pedal Ship 20 horns smaller style (3) Ship 10 each window regulator grey Ship 10 window regulator red pair Ship 20 turn signal rod Ship 15 kick vent green Ship 15 kIck vent red pair Ship 20 bottle jack bracketShip 15 door hinges (5)Ship 10 each spare tire wrench toyota stamping Ship 20 spare tire wrench toyota stamping Ship 20 clutch master cylinder used Ship 10 clutch slave cylinder used Ship 10 heaterShip 50 heater blower Ship 25 blower ducting Ship 15 blower ducting rubber Ship 10 shift boot w/ring and inner sleeve Ship 35 tcase boot w/ring and inner sleeve Ship 35 shift boot w/ring older type Ship 15 shift boot no ring Ship 10 rearview mirror Ship 15 door inspection plate pair Ship 20 inner door latches (2) Ship 10 each exterior door handles (5) Ship 5 each apron emblems with hardware pairShip 25 steering column bracket Ship 10 steering column bracket with rubber Ship 15 BTB battery tray NEWShip 25 BTB fuse box mount NEW Ship 25 lift hatch cover grey Ship 35 lift hatch cover tan Ship 75 gas pedal Ship 10 fuel line filter Ship 10 oil cooler hose NEW 15779-61010 Ship 20 78 dizzy with caps and parts Ship 100 FST glass retainer NEW pair Ship 20 bump stops pair Ship 10 vent cable pull mount (2) Ship 10 each top window felt NEW 68212-90300 Ship 5 wiper arm inserts set of 2 Ship 15 brake lines 10" NEW Ship 10 each apron weatherstrip (3) Ship 5 each door locks (2) Ship 5 each rear hatch door locks (2) Ship 5 each brake pedal rubber pad NEW Ship 5 windshield vent WS used Ship 5 windshield cowl WS used Ship 5 steering wheel firewall mount coverShip 10 kick vent WS pair one new one used Ship 5 output flange course spline Ship 10 output flange fine spline Ship 10 pile of used roof WS Ship 20 window wing mounts set of 2 Ship 20 reverse light cover Ship 5 hood rubber cushion set 51464-90800 Ship 15 hood hinge pad set of 4 NEW Ship 10 hinge pin and bushing set Ship 10 footman loop chrome (12) Ship 2 each footman loop grey (2) Ship 1 each footman loop 133-30 NEW (4) Ship 2 each door weatherstrip NEW (2)Ship 25 each vacuum hose kit 04000-11120 NEW Ship 10 each inner door striker (4) Ship 5 each door limiters aftermarket (2)Ship 5 each door hinge pins (8)Ship 1 each wiper nut Ship 5 horn relay used Ship 10 FJ40 side dome light Ship 15 side markers red (3) Ship 10 each side marker housing (2) Ship 5 each license plate lightShip 15 wiper switch Ship 15 ignition switch with key Ship 15 heater switch Ship 15 cig lighter housing Ship 5 fuse holder Ship 5 parking light housing round (2) Ship 5 each bumper hooks pairShip 20 Telescoping mirrors pair Ship 75 bumpers with threaded rods (4)Ship 10
Thanks I’ll take it! PM sentBellhousing inspection cover @Ackcruisers
Thanks. Email sent.My bad!
It's sold.
Sent email for this part.Hi boys and girls,
I'm doing another sale on some of my parts I no longer need. Some of these were in my last sale and some are from some boxes I'd forgotten I had. For those of you that don't know me, I'm a teacher and a coach. With that said I'm a stickler for following directions carefully. If you would like to purchase a part(s) I need you to reply to my personal email which is coachmesler@gmail.com
If you send me PM I will do my best to answer it, but it will NOT hold your place in line for items. If you reply to the thread and not my email it does NOT hold your place in line. Using my personal email is the easiest way for me to keep track of things.
When you do reply to my email I need your full name and address. It helps me calculate shipping costs. And yes, shipping is more expensive these days then it used to be. If the item is heavy and you live far from me it won't be cheap.
No flakes please! If you're not serious about buying the parts please don't waste my time or yours. Nothing is more annoying then me taking the time to box up parts, calculate shipping, send you an email with total costs, and then get no response.
thanx!
Craig
Item Description Ship/No Ship Cost bell housing inspection cover Ship 25 battery tray support Ship 25 radiator support short Ship 10 radiator support short Ship 10 radator support long Ship 15 water pump pulley 2 groove Ship 20 water pump pulley single groove Ship 20 hood prop short style Ship 10 heater vent cable pull Ship 25 motor mounts pair new Ship 50 Power steering bracket Ship 50 Gauge Cluster Bezel New Ship 35 hard top L bracket set of 2 Ship 20 Ashtray no door Ship 20 Ashtray Ship 40 Hood catches set of 2 Ship 20 t-case linkage and brackets Ship 25 shifter knob black Ship 10 wiper arms with blade set of 2 Ship 20 wiper arms no blade set of 2 Ship 15 radiator cap new Ship 10 wheel cylinder kit 04311-60021 Ship 10 cylinder kit 04471-35014 Ship 10 fuel filler housing Ship 25 fuel filler neck Ship 25 clutch master cylinder new Ship 40 clutch slave cylinder new Ship 25 bag of round body mounts(9) + bolts Ship 20 side mirros pair Ship 25 superwinch locking hubs pair Ship 50 ebrake lever assembly Ship 50 window wing green Ship 30 window wing red Ship 20 clutch pedal Ship 20 horns smaller style (3) Ship 10 each window regulator grey Ship 10 window regulator red pair Ship 20 turn signal rod Ship 15 kick vent green Ship 15 kIck vent red pair Ship 20 bottle jack bracket Ship 15 door hinges (5) Ship 10 each spare tire wrench toyota stamping Ship 20 spare tire wrench toyota stamping Ship 20 clutch master cylinder used Ship 10 clutch slave cylinder used Ship 10 heater Ship 50 heater blower Ship 25 blower ducting Ship 15 blower ducting rubber Ship 10 shift boot w/ring and inner sleeve Ship 35 tcase boot w/ring and inner sleeve Ship 35 shift boot w/ring older type Ship 15 shift boot no ring Ship 10 rearview mirror Ship 15 door inspection plate pair Ship 20 inner door latches (2) Ship 10 each exterior door handles (5) Ship 5 each apron emblems with hardware pair Ship 25 steering column bracket Ship 10 steering column bracket with rubber Ship 15 BTB battery tray NEW Ship 25 BTB fuse box mount NEW Ship 25 lift hatch cover grey Ship 35 lift hatch cover tan Ship 75 gas pedal Ship 10 fuel line filter Ship 10 oil cooler hose NEW 15779-61010 Ship 20 78 dizzy with caps and parts Ship 100 FST glass retainer NEW pair Ship 20 bump stops pair Ship 10 vent cable pull mount (2) Ship 10 each top window felt NEW 68212-90300 Ship 5 wiper arm inserts set of 2 Ship 15 brake lines 10" NEW Ship 10 each apron weatherstrip (3) Ship 5 each door locks (2) Ship 5 each rear hatch door locks (2) Ship 5 each brake pedal rubber pad NEW Ship 5 windshield vent WS used Ship 5 windshield cowl WS used Ship 5 steering wheel firewall mount cover Ship 10 kick vent WS pair one new one used Ship 5 output flange course spline Ship 10 output flange fine spline Ship 10 pile of used roof WS Ship 20 window wing mounts set of 2 Ship 20 reverse light cover Ship 5 hood rubber cushion set 51464-90800 Ship 15 hood hinge pad set of 4 NEW Ship 10 hinge pin and bushing set Ship 10 footman loop chrome (12) Ship 2 each footman loop grey (2) Ship 1 each footman loop 133-30 NEW (4) Ship 2 each door weatherstrip NEW (2) Ship 25 each vacuum hose kit 04000-11120 NEW Ship 10 each inner door striker (4) Ship 5 each door limiters aftermarket (2) Ship 5 each door hinge pins (8) Ship 1 each wiper nut Ship 5 horn relay used Ship 10 FJ40 side dome light Ship 15 side markers red (3) Ship 10 each side marker housing (2) Ship 5 each license plate light Ship 15 wiper switch Ship 15 ignition switch with key Ship 15 heater switch Ship 15 cig lighter housing Ship 5 fuse holder Ship 5 parking light housing round Ship 5
No, it is soldDo you still have the ignition switch? Please send me a picture. Thanks
