I put the finishing touches on my P/S conversion today and have a question. I'm using an FJ80 steering box and pitman arm (4.25 turns lock to lock). When I have the drag link connected, I'm getting a little under 3 turns lock to lock before hitting the steering stops on the knuckles. Obviously the pitman arm is a bit too long.
I was planning to measure the stock 40 bell crank that was mounted on the front cross member and shorten the pitman arm to match, but I'm not sure that's the right approach. Before I cut anything, figured I'd get some advice from other folks who have done this conversion, and see if there was a consensus on the sector shaft to drag link mount dimension, or a method that I should use to determine the correct length for the pitman arm.
