AHAH! So you've found your missing PCV valve! Congtatulations! Aren't pics great?
Sometimes, you can fix a stuck PCV with spray-in carbcleaner, or a soak in a bucket of partsdip. They only have, like, one moving part...
Also, it looks like you have one of those Toyota "Hi-Po" intake manifolds.
Also, I wouldn't worry too much about replacing those hoses...:
1) The PCV to carbbase hose looks very similar to mine. But, my hose goes OVER the valve cover, not in front of the valve cover as yours does. So it avoids running so close to your exhaust manifold. Maybe I'd just feel along the length of the hose, especillly that heated portion, assessing for soft spots. You could perhaps route your hose over your valvecover and trim out that heated portion
B) Your engine will pull, maybe 20 in./Hg at idle, less underway, more on a long downhill but probably not enough vacuum to close that hose off. Plus, any crankase venting will come through under positive pressure and should blow that hose open again. In fact, if the hose WAS closing due to engine vacuum, one would not need a PCV valve at all...the hose itself would act like a flutter-valve, only opening when crankcase pressure would overcome intake vacuum.
III) What the heck kind of carburetor is that? Ain't pics great?
