bj40man said:So you live in Equador? I bet your use will be very frequent. I would go ahead and put it in the back, first bec you dont have power steering and second because it will make a difference.
I drive a BJ40 with an Aussie locker in the back. I live in Honduras, C.A. and I tell you, there is a world of a difference. It bangs and scares you the first few times, but then after, its you scaring everyone else. You get to hear the ratcheting also on tight corners, and people approach you and tell you theres something wrong with your rig. You get used to it.
regards,
bj40man
mr_manny said:I believe a non-selectable locker in the front is not that big of a deal.
mhdsummers said:I have an Aussie in the rear and love it.
I was able to walk over stuff that before the locker I would have major traction problems.
I also had some strange braking and acceleration issues. I figured out that if your
rear tires are not inflated to the same pressure, you will shimmy to the
left or right when you accelerate or brake. Now it goes and stops straight.
Go with the Aussie.
jmaddox said:I put an Aussie in the rear of the 40 about two weeks ago. Ive been pulling to the side when I stop or start. Thanks for the info. I am going to go air up the tires now.
if you swtiched the axel shaftsHoboFire said:Hey does anyone know if you can put an aussie locker on a pre 69' cruiser? I looked on a site that listed them for 69' and up. Thanks
fj40ec said:Yes, if i'm not shure the '69 and before thatr came with 6 or 7 spline.
Aussie_Locker said:As we point out in the installation manual your tires need to be within 3/8" in circumference of each other for proper locker operation, at any tire pressure. Do not attempt to compensate for an undersized tire by adding pressure to that tire. Pressure needs to be the same on both tires on the axle, and the circumference within the specifications. You will then have a properly operating and handling Aussie Locker.
