fj40 klunking sound in tranny/transfer area
Aurora, CO
regarding 75 fj40 with 4spd and 3spd transfer.
when i first put it in gear (any except reverse) I hear an ever slight klunking (single klunk) sound when accellerating (doesn't matter if I start of really slow or slam on the gas). Will happen anytime I decide to go from one gear to the other, but won't happen till the truck lurches forward from the shift. Never happens in reverse (slow or fast launch)
In other words, if I goose the gas, i'll hear the clunk right away. If I feather the gas and take it slowly, the klunk will happen, just at a lower pitch and take longer to reach the klunk sound.
Is this my reverse gear swinging around in the tranny? or could it be the transfer somewhere? If so can I use the adjuster screw on the side of it to stop the noise?
thanks!
K
might grease the driveshafts and u-joints up, I bet the noise is actaully in the splines on the shaft. I had a similar noise in my 60........just needed some grease. Don't over grease the slip joint however......if ya do it won't compress
luckily I have the center hump out so I can somewhat localize the sound. Today I did a bunch of "testing" as mentioned on POR. I noticed that if I hold the transfer lever towards the left while in H2 the klunk is GONE. if I don't hold it there, than I can see the transfer case lever jerk to the left at the exact moment the klunk occurs. klunk occurs in H4 as well. In L2 or L4 I hear no klunk a all. all ujoints etc look good and have no play in them....plus no clunk in Low seems to rule those and the pumpkins out. No klunk in reverse in any transfer range.
...can I adjust the transfer lever to pull harder to the left initially?
Thanks!
K
Are you using the old style Advance Adapters crossmember?
If so you may have a fudged detent shaft. The shaft gets jammed into the case under hard use and damages the retaining plate that locates it. If the shaft moves far enough it can cause undo stress at the hi-lo shift collar or sleeve. If it gets bad enough it can cause the t-case to jump out of hi.
Have seen this twice in the last month.
nope, no AA stuff. just a 4spd tranny and 3spd transfer.
k
[quote author=hammerhead link=board=1;threadid=14840;start=msg140667#msg140667 date=1082179738]
...early '74 transition period T-case input gear...
[/quote]
yes, i do have the said transition gear. The one I used is from a kit, I forget who I bought it from (maybe downey?). It is the made in japan gear that looks to have a package that infers it's a marine gear..or something like that.
is that my issue and do I just have to "live with it"?
K
