The heater shutoff valve for my '76 FJ40 is leaking. Does anyone have one that isn't clogged and, hopefully, doesn't leak that they'd be willing to sell? I believe the OEM part # is 87240.
Paul! Thanks for the reply. I'm on a conference call right now (kinda boring one obviously!). So, I can't run out to the 40, but here is a weblink that shows it.
Ugh, not sure that can be fixed. Mine leaked internally, so couldn't keep hot antifreeze from circulating through the heater when the was knob pushed all the way in. Installed this all brass shut off valve:
It'll shut off manually to the OEM in warm weather, but won't help with your leaky shaft in the winter. ToyotaPartsDeal sells the Control Valve for $86.73. Not cheap!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
