FJ40 Gow di I remove the intruments and mid console/cluster?
Hi all,
I am trying to change some bulbs (brake and park brake) in the centre console of my 1982 FJ40.
I have the antique looking speedo and dash :-)
I loosened the 4 screws on that panel but it will not come out. how do I get to the bulbs?
i also tried to remove the instrument cluster to see why the ammeter isn't moving. I lossened the 2 scrwes but - although loose and mocing, the cluster cant pull forward.
How do I remove the clister to get access to the rear of it?
Kind regards
Bernt
Disconnect the speedo cable.
also on the later 40's it helps to drop the steering colum, the 2(i think) bolts at the bottom of the dash, then you can get it out easier.
I can actaully get my hand in the back of the cluster to change bulbs without pulling the cluster all the way out.
it almost sounds like you have a 83 dash.....thats the only one i can think of with 4 screws holding the dash in......the pre 83's have no center panel in the dash, you have to reach behind to get to anything
