bmoonhajjar
GOLD Star
- Location
- United States
I have (what I consider to be) a very complete FJ40 Wiper Assembly that should work for 1968-1974 depending on models, modifications, etc. Everything pictured is part of the sale. I have attempted to photo document and describe everything to the best of my knowledge, as well as post two videos (a first for me) testing the high and low speed of the assembly.
Main Wiper Assembly was completely disassembled, degreased, housings striped, primed and painted. I even disassembled the primary contact and re-soldered it, which is a pain. The wiring is in good condition and is original. The original connectors (both male & female) are in good condition, so I left them alone. All contacts were thoroughly cleaned prior to rebuild. Internals were reassembled using AeroShell 33 Grease to last another 50 years if need be. The original wiring harness is intact and the wires are good, as are the bullet connector ends. The auxiliary (room) light single wire is new. I will do my best to list everything that comes in the sale.
One (1) Main Wiper Assembly w/ Motor
One (1) Original Wiring Harness w/ Room Light Wire Lead
One (1) Room Light Wire to run power to your room light from the harness
One Set (Pair) of Wiper Pivot Pads
One Set (Pair) of Wiper Arms
One Set (Pair) of Wiper Nuts
One Set (Pair) of Wiper Pivot Nuts
One Set (Pair) of Wiper Pivot Washers
One Set (Pair) of Wiper Packing (rubber ring gaskets)
Nine (9) Wire Harness Clips (these are aftermarket with no screws)
Four (4) Wiper Assembly Bolt Hardware
One (1) Contact Cover (Very Hard to find in good condition. This one is "useable")
My best guess-timate is that if you were to purchase all of these parts (if you can find them) you would be paying well over $700
$800
$800
