FJ40 clutch hub same as FJ60 clutch hub?
macdaddy59
Niceville, Florida
So is the FJ60 clutch hub (the part that holds the thriw out bearing) the same as the FJ40. Can they be used interchangably? When I looked up the part number the same part number seeemed to be listed for both so I am just checking.
If the clutch fork is cast iron and not stamped steel should be good. I have a four speed in my 68 but kept all the early clutch pieces that match the flywheel on my original engine. Could switch to later style
clutch but flywheel has to match the rest of the clutch assembly.
