fj40 axle is stronger or fj80 is
Seattle
Ok so what do you think is stronger off road a stock fj40 axle or a fj80 axle im thinking in terms of both the front and the rear. what do you think?
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
Well,
Let's think about this for a bit.
The 80 weighs a lot more than the 40.
The axle shaft diameter on the 80 is larger.
The trunion bearings on the 80 are larger.
The 93 up 80 rides on an FF rear with 2 bearings per side instead of one.
What do you think?
On the catwalk.
Website
www.lslc.org
I think a coarse splined axle of the early 40's are way stronger then the 80's. Not to mention the fact the birf itself is 40% smaller then a 80 birf. So they must be 40% less likely to grenade. ::) ::)
Seattle
im thinking it would be sweet to see an fj40 with a set of fj80 axles under it or maybe a just a fj40 body on and fj80 cruiser that would be cooler.
On the catwalk.
Website
www.lslc.org
[quote author=lx450landcruiser link=board=2;threadid=7517;start=msg62883#msg62883 date=1068782533]
[/quote]
It's been done...
ginericLC
Wagon Wheeler!
MH, IDaho
I thought the axle shaft diameters were the same on the 30 spline axles? How are the lockers interchangeable if they are not. I also remember the Australians saying once that the semifloating axles were actually stronger than the fullfloaters as they were a bit larger. Not in bearing load carrying capacity, but in actual axle strength. It could have all been hogwash. I'm not an engineer. Birf stength :doh: the 80s are like 30% larger.
cruiserdan
Moderator
As far as Shaft diameter is concerned, the area wher the shaft seals ride is larger in diameter on an 80. EG the part number for the tube seal on a 40,55,60 is 90311-33085, indicating a shaft diameter of 33 mm and the 80 series part number is 90310-35010, indicating a shaft diameter of 35 mm.
D-
woody
Staff member
Admin
Toquerville UT
tube seal and shaft size are irrelevant.....on a FJ40, the shaft "enlarges" at that point to provide the seal surface. I'm gonna go on a limb and state the 80 enlarges more...lol
The side gears of a 40 and 80 series are both 30 spline, front and rear. Since spline "sizes" are all relatively identical, this is your weakest point. In order for any size diameter shaft to fit into that side gear, it must neck down to that 30-spline diameter. Additionally, on birfields, the FJ40/55/60/62 is 27 spline where it inserts into the birf, and that's why 90+% of all front end breaks occur at this neck down point (assuming upgraded birfs which in stock form is weaker) (even shafts designs which eliminate the retaining clip groove are weakest at this point)
Break a rear FJ40 shaft (I have) and it breaks in the spline area, just where it begins to neck larger for the balance of the shaft size.
Additionally, a thicker shaft allows less opportunity for equal twisting distribution down the entirety of the shaft. PIG from PolyPerformance is promoing 300M minitruck shafts right now, he's kept the diameter SMALL and greatly strengthened the material...this will allow the shaft to deflect more under shock load, but still be stronger. (see the Vendor forum at pirate4x4.com/forum)
Birfields, the 80 wins hands down. But front inners and rears, because of the spline counts, are effectively similar.
Given identical materials and design, spline counts = strength. 27 vs 30 vs 31 vs 35 vs 40....since each spline is the same size, the only way to add more splines is to increase diameter.
(BTW, am I allowed to argue with cdan, or will he vaporize me?!?) hehehe
Port of Indecision...otherwise Northern Arizona
[quote author=woody link=board=2;threadid=7517;start=msg62971#msg62971 date=1068814272]
[/quote]
You gave him vaporizing power!? :eek:
I'll remember to duck...
-H-
Somewhere in the foothills...
Woody,
>> (BTW, am I allowed to argue with cdan, or will he vaporize me?!?) <<
Even though C-Dan was "Queen for a day", I doubt anyone got screen shots of his lofty status. The smartest thing you have done this year is remove his "Forum God" standing and return him back to Hall Monitor. You should have no fear of vaporization by C-Dan.... However, I *do* have screenshots of my ability to do "Global Destruction" on this forum. Unfortunately this takes all of us out at the same time.
:D
-B-
cruiserdan
Moderator
I would never argue with the Great Wood One.
I am not opposed to spirited discussion. 8)
In fact, the Wulf and I discuss wheel bearings often :flipoff2:
woody
Staff member
Admin
Toquerville UT
Now for more discussion, full float versus semi-float. A fullfloat rear axle shaft is sized identically down it's entire length, in order to maintain it's removeability status without dropping spindles and such. However, semi float shaft is LARGER throughout the entire length, excepting the spline area. STRENGTH-wise, the semi is stronger, however greater vehicle load capacity is maintained with a fullfloat since the weight is on the tapered bearings and not on the shaft itself.
Either way, c-clips suck tho....
