FJ40 1974 rear drum stuck
  • Thread starter rawprawn
  • Start date
  • Watchers 3
R
rawprawn
Sydney
I have a 1974 FJ40 with a rear semi floating axle and I need help on removing the drum. I was expecting a retaining screw but seems not to be present? I also tried to adjust the cylinders using the brake adjuster gap in the back but no success removing the drum. Any useful suggestions or do I just brute force it at this point?
R
rawprawn
Sydney
Picture of missing retaining screw
Screen Shot 2021 10 30 at 31223 pm
Skreddy
Skreddy
Stanwood, WA
What’s the back story? Been sitting or recently running and driving? PB Blaster or your favorite flavor of penetrant along the seam between axle and drum is a good start.
1
1969FJ
Arizona
I believe that threaded hole can accept a bolt to put force on the drum , to move towards you.
3
3_puppies
Helena MT
X2 on a sledge hammer, the drum will "freeze" to the axle shaft, it will need a little persuasion
Goldbug
Goldbug
Rhode Island
PBlaster was what did it for me, left overnight. Tried sledge hammer, heat, and the bolt but none of them did it.
jmylie
jmylie
CT
Use a little anti-seize on the axle when you reassemble. Helps to keep the drum from rusting onto the axle.
Penetrating oil and hammer should be able to break the bond between the drum and axle.
Similar threads
PipFin
Replies
18
Views
555
firemanj92
firemanj92
PacificaFJ40
Replies
4
Views
346
PacificaFJ40
PacificaFJ40
turbodrabbit
Replies
4
Views
386
turbodrabbit
turbodrabbit
