Over the past 5-6 years I have accumulated many parts from restorations I have completed. All the parts I am listing are in restorable to new condition. I also have other parts that aren't listed so pm me if you have need for parts not listed. I have not been able to get any of the pics to load, so let me know your interest and I can text you pics.
1976 Transmission hump cover (4 speed), good condition no rust thru but some surface rust $250-
1976 spare tire carrier fits LH side with hinges in V. good condition $210-
Set of front seats from 1976 with seat sliders (sand blasted) in extremely good condition $ 450-
Set of front seats from 1975 with seat sliders (sandblasted) in V good condition $ 410-
Radiator from 1976, removed from running vehicle, no leaks in good condition $ 50-
Four piece roll bar protector set, in like new condition $ 110
Three piece lower dash protector pads from 1976 in excellent condition $ 100-
Wiper motor assembly removed from a 1978, no rust works fine in good condition $ 70-
Bestop (Trailmax 11) rear seat new $ 225-
Emission cover for fuel tank from 1976 sandblasted, primed and painted black $ 30-
Fuel tank and fuel tank cover off a 1976 no rust in very good condition $ 120-
Rear heater very little surface rust, tested with no leaks from 1974 $ 70-
Rear heater from 1976, sanded, primed and painted black, with water lines $ 160-
New rear sill with cover for 1976, has all holes and nuts for spare tire carrier LH side $380-
Two fiberglass hardtops in restorable condition, no thru cracks $ 125/each
Two front OEM floor mats from 1975/6 in good condition $ 75/each
Rear floor mat from 1974 with heater cut out in good condition $ 45-
F-155 motor 1973 partially torn down with all parts, to include new .020 over pistons $ 300-
Rear bolt on tailgate sandblasted and primed v. good condition $115-
Hood from 1975, sandblasted, repaired and PPG primed no rust $ 475-
OEM front seat belts from 1975, good condition $ 30-
Distributor removed from 1974, with coil and plugwires $ 70-
Distributor removed from 1976, with coil and plugwires $ 70-
Front heater from 1976 in good condition $ 35-
Bestop soft front doors in v good condition $125-
Bestop soft front doors in as new condition $ 180-
Painless wiring harness in as new condition $ 100-
Two OEM bottle jacks with rods in v. good condition $ 85/ea
Set of four OEM front door hinges, sandblasted, primer painted , no rust $ 45-
OEM metal center console, sandblasted and primer painted, no rust $ $50-
Side step support braces, sand blasted and primer painted in v good condition $ 80-
Thermostat hswg from 1976, sandblasted,primered and painted black in v good condition $ 60-
Fuel filler door (fits 1974-78) min surface rust $ 60-
Hardtop front channel removed from 1972 with repairable rust $ 90-
Intake manifold from 1976 , cleaned and painted black in v good condition $ 60-
