FJ GM Alternator
Houston, TX
I am about to install one of these on my stock Sept. 1974 built FJ 40 with an F engine. Can you recommend a GM alternator that does not require any special adaptors and would fit directly onto the hardware already available. I am aware (from previous posts) the wiring may be different due to the higher amperage.
Thanks
Welcome.
I am not aware of a GM alt that is a 'bolt in' deal, other than possibly a mean green...
If your alt is in the stock location for an F engine(lower drivers side of engine) the bracket requires you to have an alt with two ears. Some alt shops can take the guts of a GM alt and put them into a "toyota" housing, it is acctually a conversion housing that is made for this. Have installed a few and they seem to work well.
You would do best to stop into a place and show them what you want to do, as talking about it on the phone can get confusing to some.
Good luck!
-Steve
