Tired of seeing about 60% field of view (FOV) out of your FJ's backup camera? Don't like your stock tire cover but don't want to see the ugly camera housing exposed when you remove it?
We were too so we came up with Camera Armor. Not only does Camera Armor look better and provide a 100% FOV out of your backup camera but it also has a hidden bracket mounting system so you can mount a GoPro, antenna or light in the protective area of your spare!
As with our winch mount bumpers, we provide this to you in bare .125" thick steel. You can paint, powdercoat or whatever makes you happy. The aluminum end cap is anodized clear to protect the aluminum from the weather and keep it looking good. Hardware mounts flush and is stainless steel with zinc coated nutserts for long life.
Installation is simple, pull off your spare wheel/tire, slide the camera armor over the studs and reinstall your wheel. Done. You can then leave it with the filler bracket or swap out brackets without removing the wheel again.
When you purchase Camera Armor you will receive:
Camera Armor body
Aluminum end cap/bracket mount
Filler bracket (does not protrude from under the cap but fills the slots so it doesn't collect dirt/water)
Default 3 way bracket with predrilled holes.
Extended bracket 2" longer than the default with no accessory holes drilled. (you can bend, drill and cut to your heart's desire)
2 x stainless steel flat allen head screws (1/4" x 20)
Paint or coat as you wish, you can also paint the aluminum cap, make it yours.
Buy yours here: http://usoffroad.us/store/fj-camera-armor
Camera Armor body
