fj 60
Discussion in '60-Series Wagons' started by airon23, Feb 21, 2004.
  1. airon23
    airon23
    712
    Media:
    11
    Albums:
    1
    293
    Jan 5, 2004
    Reno NV
    my newly bought fj60 doesn't seem to be holding a charge. brand new battery but after a few times of starting and then leaving over night doesn't start. any ideas of what could be the problem?
  2. VTCruiser
    VTCruiser
    3,458
    17
    Sep 12, 2003
    Tacoma, WA
    The alternator may be a good place to start.
  3. Mike S
    Mike S
    2,537
    16
    Aug 19, 2003
    I suiggest that you first check and clean all connections - alternator, terminals, ground etc. This is sometimes the problem. After that, get the manual out (you have the manual, right ?) and start doing voltage/amperage checks.
  4. TonkaC
    TonkaC
    339
    Jun 20, 2003
    Watertown, NY
    try and disconnect the battery at night and see if it still dies. If it doesn't then you might have something that is on during the night and dropping the battery. I had a trunk light that was killing one of my cars and took me way too long to figure it out.
    Chris
  5. atoyot
    atoyot
    793
    1
    Apr 7, 2003
    Spokane
    Did you check the blinker fluid? :slap: check the alternater.
  6. cosmo
    cosmo
    1,104
    Media:
    3
    Albums:
    1
    6
    Dec 1, 2003
    Bend, Or.
    "Blinker Fluid" That's Great! Thanks for the laugh. Cheers, O.
  7. wildman4wheeler
    wildman4wheeler
    267
    Nov 11, 2003
    Knoxville, Tennessee
    [quote author=O' man link=board=1;threadid=11866;start=msg108864#msg108864 date=1077530892]
    [/quote]
    i get my cousin all the time with that one
  8. snelson
    snelson
    70
    Sep 8, 2002
    i would check if there is a parasitic draw on the battery. the simplest way to do that is to make sure that all of the loads are turned off and then disconnest one of the terminals and i usually do the positive and then connect a test light in line with the cable by connecting one end to the cable and the other to the battery terminal and if the test light lights up then you know there is somthing on that shouldnt be that is draining your battery. then i would check the alt good luck.
  9. DenverCruiser
    DenverCruiser
    580
    36
    Sep 30, 2003
    Woodstock, GA
    Make sure the connections - & + to the battery are very tight and secure. If not, this easy solution can be your problem.
