Fj-45L Window gaskets (1 Viewer)
I need gasket for the rear and side cab windows. Toyota dealer says they are unavailable.
Anybody found a substitute or have any ideas?
Thanks
Jeff
SOR used to have the rear window gasket, the corners are out of production, the rear window will work for the corners if you cut and glue- don't know if you can get two out of it, try ccot.
AFAIK the rear is totally unobtanium, but SOR should have repro gaskets for the corners. Not moulded at the 4 curves like stock, but definitely the right shape and size to get the job done.
Before I realized that I could get the corner weatherstrips for my LWB, I went ahead and took a 40 weatherstrip and cut it down. It worked so well, I never bothered taking it back out when I got the 45 weatherstrips.;)
