FJ 45 DISK BRAKES P/S NEW SUSPENSION SET UP
HI IN THE COMING WEEKS WILL BE INSTALLING 4 WHEEL DISK BRAKES SAGNAW P'S AND NEW SUSENSION KIT ON THE FRONT WHAT IS THE BEST CO TO USE ........HELP THANKS VERY MUCH ITS A 1965 FJ45
The best company to have it done at, or the best company to supply you with the parts you need?
The former depends on where you live. If it's the latter, check out 4x4 Labs or Advance Adapters for the PS mount. Cruiser Outfitters is an AA reseller and has a lot of suspension stuff. Front disk brakes is best to use a later axle. You get Toyota 4 piston calipers, easy to source parts and upgraded axles. Rear disk brakes have a few options. the easiest is bolt on caliper brackets, Chevy truck rotors with the centers machined out, and 78 Monte Carlo front calipers.
It appears that JTOutfitters has everything you want, but you might well run into issues with customer service, parts availability and a very disappointing front disk conversion kit.
thanks i read a post about jt outfitters rather i stayed away from them . i plan on doing the work myself really need parts that don't have allot of problems iam sure they are some one out there has took the time make a good kit .. i live in wa st and restored a FJ40 afew yrs ago and used specter off road and a co back east for used parts .... i know body wise i need a set of correct tail lights housings and i know i can get new lens thanks for the help
