Even if you don't need any parts you can always come over for a cold beerThank you! I'm sorry I'm lowering the volume of 70s in TX! I need to quickly go through my list of hard to ship wanted parts before you are a 12hr drive away!
IMHO, (and over a decade of experience in Search and Rescue) these "old" Cruisers do the job BETTER than anything built nowadays. I can't count how many times I have come across new "off road" jeeps and trucks that have broken something or had some electrical failure for a hub or locker and subsequently been stuck or broken down.Love seeing people use these rigs for more then just trips to the coffee shop. Just cause they are old and don't have "TRD" next to their badging doesn't mean they can't do everything just as well. The trip and all the passes you did is on my bucket list to do in my 77, I was hoping I'd be the first in a 77 to do them...
I actually just registered for a training event at TMMTX for Oct 11-14 that I'm curious if it will stay on the calendar or get virtualized....if its still there I'll have to see if I can hunt you down!
I'll keep you posted!!Feel free to hunt me down. That is right after MPTA so time should be on my side here at work.
That will be right after MY22 Tundra MPTA so things won't be so crazy. Let me know! I am sure I will be around but I bet you will be at the visitors center and not the actual plant for the training sessions. It seems like that is how TMMTX does their training.
I hope so! I feel bad cutting anything up, but it will make it much more useful for us!Hello,
Once it is installed and painted, it will look factory.
Keep up the good work.
Juan
@Blomdala I am going to install this same security system. I just ordered it.View attachment 2580259View attachment 2580260
I tapped the radio power and ground since the DCDC has a nice constant 12v out available for it. In my testing, the alarm never took more than 0.7A so I’m not worried about it. I also popped the glas break sensor into one of the switch spots. View attachment 2580262
There is a little 3 prong wire under the dash, it has a very convenient connection for the ignition switch. I snagged a pin to put into that. Trying to keep things unmolested.
It’s not perfect, but I like having the Toyota fob, and it works good enough ha. I’ll do some digging and see what I can find for what I used. But you’re right it was very few. Power, ground, unlock signal, lock signal, drivers door switch (I didn’t add passenger door sensing yet), ignition, horn/beeper, and parking lights.@Blomdala I am going to install this same security system. I just ordered it.
There are about a million wires coming out of that module. But it looks like you only used a few of them. Do you have any more details handle on all of that? I'm pretty sure you're the only person in the world that has done this ... or at least done this and documented it.
That may very well be why I didn’t connect it. All I do is tap into the ground button for the dome light, It just wants to see ground for the alarm too.I'm with you on the fob. Aftermarket fobs are super clunky and massive. It's like they're trying to prove something.
I'm looking forward to hearing your thoughts on the wiring specifics. I don't think the passenger door has a sensor in it? Unless mine doesn't work ...
I appreciate the kindness! If it helps one person then it’s all the more worth it!Just got sucked in to the vortex and reread this entire thread from start to now. Not a bad way to recover from Christmas breakfast, before heading off to Christmas dinner!
@Blomdala this build thread is one of my faves on here. Thanks again for documenting this journey. Look forward to the next chapter.
