First FJ40 Buy Advice
Omaha
Howdy, first post! I’m mostly looking for advice. I’m interested in buying my first FJ40. It’ll be in the mid $20K range. As far as I can tell, it’s a 1976 model (late 75 production) US spec model given that the VIN on the frame, door, and engine match the vin decoder I’ve seen here.
I would’ve preferred an FJ40 that had never been repainted and had not been sprayed with bed liner underneath, but after almost 50 years it’s hard to find something like that without breaking the bank. Nothing seemed concerning on the frame as far as I could tell.
The odometer has rolled over and at one point wasn’t working, but the current owner replaced it and is now functional. The engine sounded fine and the gears shifted without concern. My only concern was an oil leak but the owner messaged me after my test drive to say he took it into the shop. Apparently, there was a plug in a venting tube that caused pressure in the valve cover and thus, oil to leak. They now rectified it and now there is no leak. The owner said I’m welcome to take it to a mechanic for a pre-purchase inspection.
The current owner doesn’t have much history on the vehicle, other that he bought it in Minneapolis from a gentleman that was restoring several FJ40s.
I’m looking for an FJ40 that I can enjoy driving often. I’m not looking for a totally original museum piece, just an opportunity to enjoy the fun spirit of the early Land Cruiser. The first FJ40 I buy will probably be the only one I buy.
What do y’all think? Is there something I’m missing or not considering? Thanks for your advice!
It is a nice looking cruiser … there are issues … usually a lot more unseen then
The rear sill replacement could have been much better … or the side corners were skinned over … either way it’s suspect
The rear body mounts are missing on the rear corners above the tail lights
There is extra rear bracing in the wheel wells
I do not see a pcv hose going to the base of the carb nor do I see the valve cover venting to the weber air cleaner
Once the seals have been compromised there is a chance it will most likely still leak … just not as much
But… your crankcase ventilation system is not functioning correctly … what did they do exactly to correct the leak?
The engine shot after they fixed it?
The missing spare carrier is also suspect because it’s missing mounting holes on lower spot … so down there was ‘fixed’ but why not put the carrier back in? Unless they do not think the repair can handle the weight?
Just thinking out loud
Wow, I honestly appreciate how quickly everyone has responded and for catching things I would’ve never noticed.
Apparently they simply removed the misplaced plug. I have no idea how long it was in that condition. I drive it for about 35 minutes and there was a lot of oil leaking down the right side of the engine near the rear
As for the carrier, he has it but he said he didn’t have the rubber seals to mount it to avoid metal-on-metal contact.
This picture is before the fix
I am concerned that they just plugged it
It was spraying out oil because there’s most likely a lot of back pressure because I don’t see a pcv hose going to the base of the carb
Is there no pcv?
I’d check out that stuff more … if it’s masking a bigger issue like blowby
Have it compression checked
Is it close to you?
Is there no pcv?
Is it close to you?
Yes, we’re in the same city which is nice, but now I’m getting the feeling maybe there are too many unknowns with this vehicle
I just noticed that the pcv is on the rear end of the side cover … so it is there
You would need a hose from valve cover to an elbow off the weber air cleaner base
So then the system would work correctly
Do check the compression anyway … that will tell you condition of the engine
