Now that I've shot thru my 2nd quart of brake fluid . . .
IF the master is not properly bled (was 'bench bled'), would that allow air to be sucked in 'behind' the M/C piston 'valve' ?
was doing two-man bleed (started with front cause that's the part I worked on, m/c was not replaced...but is pretty new looking....could a poor quality m/c allow air to be sucked in behind...like where bolted to booster ?
Would get little bubbles,,,,soda pop sized,,,,,even after 3rd 'coffee cup' voloume of purge....
Told person pumping,,,(after the 3rd cup) just keep on pumping...left bleeder cracked....never saw 'suck back'....but air bubbles almost became foamy....WTF ?
Is the 80 brake lines sooooo loooong, they take this much to bleed ?
(oh, the 'bench bleed of m/c was cause I thought maybe I bled m/c dry....it got really low....)
This is getting old....
. . .at wits end
. . . . .spending all my $ on brake fluid
TIA
Pete
. . .at wits end
TIA
Pete
