fire extinguisher?
10# CO2 if you can afford it. The powder A-B-C types are OK so long as you don't have to use it on your truck. Keep a small (5#) A-B-C as backup or to loan but use the CO2 if it's your stuff burning.
-B-
I don't suppose an OBA CO2 tank (Power Tank, Source, etc) could be used as a fire extinguisher with a different nozzle/horn?... Maybe not enough flow rate with the regulator we use? Anybody?
Hoser,
I have a fire extinguisher horn for my CO2 tank that I picked up on eBay for about $5. It attaches to the tank's regulator with a quick release connector. The biggest problem is that a fire extinguisher is designed to dispense liquid CO2 where our tanks are designed to dispense CO2 gas.
However, our CO2 tanks will work and I have tested it with a small fire. As you will remember from Boy Scouts, a fire needs 3 things; oxygen, temperature, and fuel. An "official" CO2 fire extinguisher dispenses liquid CO2 which is both very cold and it eliminates the oxygen that the fire needs. Our tanks can do both but if used in the conventional manner (valve up) it will extinguish the flame by displacing the oxygen.
I ran a second test by turning over the tank so that it would dispense liquid CO2 but that was not what I would consider a successful test. It was hard to tell how well this would work in a real event because the flame went out so quickly. I couldn't tell if the liquid CO2 would cool the fuel. I also don't think the valve would flow very long when pure liquid CO2 was coming out.
-B-
Beowulf--
I don't think a CO2 extinguisher dispenses liquid CO2 otherwise there would be a pick-up tube from the valve to the bottom of the tank. I have used them and the CO2 gas is dispensed at such a fast rate that it blows very cold. The hose and fittings on an extingiusher are noticeably larger than on our portable air tanks.
So, I'm thinking with a horn/nozzle, ours will work but won't be as effective as a dedicated extinguisher. What we need is a Wye adapter so that we could plumb in another trigger operated valve that allows for a faster rate of flow--just like the one on an extinguisher.
Here's a diagram I found on the web. I don't see a pick-up tube.
http://www.dcfp.navy.mil/equip/co2.htm
hoser said:
Beowulf--
It could also serve double duty cooling beer.
The OSHA site says the primary way the CO2 extinguisher is effective is in displacing oxygen.
It also looks to have the pick-up tube you mentioned.
The CO2 can't come out of the nozzle as a liquid because it's only a liquid when it is under pressure. As soon as it exits the tank it turns to dry ice, then evaporates in a very short time. Basically it's just a cloud of dry ice crystals that quickly turn to CO2 which displaces the oxygen.
-B-
Generally, one of the first things that goes bad in an engine fire is the hood release. Most FD's use different methods on car fires as far as getting the hood up, it can be a very real pain. Some use a tool that "reaches" for the release, some have a piercing nozzle they just smack through the hood, some a pry bar over the tire to crimp the hood and many other styles.
I would actually suggest dry chem in the 5lb size, get everybody back, do what you can, grab what you can, and get the hell back! If it is anything to it your going to need lots o' water, as much as we love these things the fumes they put off (especially the interior) will hurt you and it is just not worth it.
Being prepared is real good, getting hurt for something that is covered by insurance just isn't worth it.
I will now stop being a dark cloud.
Scott
For your frame-up restored classic I would go for a Halon FIREBOTTLE.
www.firebottleracing.com
Even though HALON is no longer made it is recycled and available for these products at a pretty affordable price.
For the burning Jeep throw him your Home Depot special. My experiance with car fires is that they can usually be put out with a small extinguisher if there is one used right away. Most of the time though the owners just stare at the fire and by the time the Fire Department arrives the cars are pretty far gone and the fire guys earn their pay even with a one car fire. Very nasty black smoke.
Also I recently replaced my home extinguishers and let my son use one of the old ones on a small fire. I highly recommend this at your next camp out. You will have fresh extinguishers, Smokey will be happy you put out the fire and your kid/spouse will have practical life/property saving experiance.
I have a 10# Halon and a 10# Dry-Chem.
If you "save" your truck with an ABC type extinguisher, you may have totalled it with corrosive powder. That stuff ruins paint and electical components. I toyed with the idea of group buy on Halotrons. Decent prices here...
http://www.smokesign.com/halfirex.html
CO2 doesn't have range at all. Any wind and it's pretty useless. Halon worked great, but it's not ozone friendly and has been mostly outlawed. Halotron has range and works almost as well as Halon.
The manufacture of new Halon has been stopped but recycled is still available and legal to use. The last of it should be used for a worthy purpose, Like saving a Landcruiser from a fiery death.
I'm laughing at that, but it is true. :D
Of course the Fire guys want you to let it burn so they have a fully engulfed car to play with. They'll never make the news if you put it out with a $5 Kmart extinguisher.
Thats a Firefighter glamour shot. :D What's the first piece of equipment off the rig. The Camera. :rolleyes:
Nothing I saw in that article would make me think twice about extingushing a small fire in my vehicle. But then again I plan on using some common sense. Judging the severity of the fire by amount of smoke and heat ect...
