sometimes it goes up, often just goes partially up, always goes down.
tips/hints?
lube, oil, corrosion X, etc?
thx!
tips/hints?
thx!
no i'm saving that option for now, it would just be nice for it to go up like normal when FM is selected as audio input.Are you pushing the up arrow on the antenna button?
Yes it goes back to the last manual setting. I find mine is also finicky. If you get a bush bend or corrosion it will also act inconsistent.I think he said that because it has a memory, and using the up/down in some fashion resets that memory and works differently than turning the key or hitting a radio button.,, I think
Well heck I would have never thought of that! That’s pretty cool thx!!Yes it goes back to the last manual setting. I find mine is also finicky. If you get a bush bend or corrosion it will also act inconsistent.
(I've never done it but) I'd wipe it with a dry lubricant of some sort - anything wet will just attract grime and build up over time.Dumb question and just the kind I assume that folks here will have strong opinions on - manual says clean antenna with “clean, dry cloth.” I’m about to do that, but should I also spray silicone or apply some grease? WD40? Leave naked?
I put some lithium grease on the plastic cable and on the antenna.should I also spray silicone or apply some grease?
