Finaly, ordered the OME setup!
Discussion in '60-Series Wagons' started by phoenixrider, Feb 22, 2007.
  1. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    After all of the questions and doubts, went Kurt at Cruiser Outfitters and ordered the OME Heavy/Med with an ADL for the rear in case I need it. Went with the more 'softer' shocks. Ultimate kit, of course.
    Guess I better start soaking up things w/PB Laster :)
    Thanks all for the feedback, and thanks Kurt!
    :cheers:
  2. baldredhead
    baldredhead
    536
    4
    Oct 28, 2004
    bay area, ca
    don't forget the bushings :beer:
  3. Front Range 4x4
    Front Range 4x4
    2,854
    Media:
    23
    Albums:
    1
    7
    Oct 1, 2005
    Colorado
    Way to go phoenixrider, you won't regret it.
    Yep, start hitting with PBBlaster.
    :cheers:
  4. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    well, at least installing it won't be all that difficult. My off-raod buddy owns a Toy repair shop so I'll be able to do the work there on a weekend with his help - for a case or 2 of beer!
  5. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    When you're installing the new leafs, start w/the fixed eye, then do the shackeled one, then set the axle on the centering pin. MUCH EASIER!
  6. nicholastheczar
    nicholastheczar
    1,414
    8
    Aug 23, 2005
    Magnolia, TX
    Nice! I can't wait until I order mine.
  7. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    Yeah, well, like I said, I'm able to do this at my bid's shop - and he's done dozens of these things, so hopefuly, things should go pretty smoothly, and we'll be kicking back drinking some beer at the end of the day looking at the lifted FJ :)
  8. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    I would recommend loading running around town with some weight in the back to soften that bad boy up. I put a load of sod in mine and it went from riding like a tank to riding like a pickup. After some loaded up camping trips it is a good ride.
    When I had my first frosty beverage to admire my work I was greated sourly by the fact that I had put my left spring on the right and visa versa and had a mean lean. Two days later after inquiring on mudd I swapped the sides and could finally could enjoy a cold one and admire my work.
  9. DirtyLittleSecret
    DirtyLittleSecret
    1,398
    Sep 21, 2006
    WA
    I agree with these guys.
    GOOD FOR YOU ON ORDERING FROM KURT. I will NOT make the same mistake again (ordered from the other primary source from around here...and am still awaiting a response from them)! At least I know Kurt will be fair/honest and knows whats up.
    Enjoy the battle...you will win in the end.
  10. JohnnyBoy
    JohnnyBoy
    154
    Nov 2, 2006
    Calgary AB
    i like beer and looking at lifted yotas. need more help?
  11. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    You're lucky, when I did my wrenching outside in the sun in Phoenix, I had to keep all my wrenches in a coffee can filled with water so they would stay cool enough to actually hold in my hands!:crybaby:
  12. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    Are there good instructions that come w/the kit from Kurt? So we'll know which spring is which? I helped my friend yesterday swap a rear end and put on the OME springs on a FJ40. The customer had ordered everything from MAF, and not a single piece of instruction anywhere. Everything went pretty smooth, until we had to figure out which way the 4+ anti-inversion shackles had to go. Instructions would have helped with that :) Just hope there's not left and right springs on the 40 as well....
  13. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    The instructions are sparse....the shackles have enough info to make it easy. Kurt will answer your questions as to what goes where.
    Give him a call after you get the stuff and it will be clear.
  14. CruisinFJ60
    CruisinFJ60
    6,158
    Media:
    219
    Albums:
    8
    36
    Oct 19, 2006
    Ft. Worthless, TEXAS!
    buy a propane torch and burn them biotches outta there it helped me like a mofo!
  15. azaussie
    azaussie
    459
    Feb 14, 2005
    The shackles come with good instructions. On the rear the "A" spring goes on the drivers side. On your buddies lift with his help it will be a super quick install. Mine when on in less than 3 1/2 hours last W/E. 2 things that slowed us down a tiny bit were both removal related. The old front shocks were difficult to get off - but 2 mins with a cut off wheel and off they came. The old steering stabliser required some pretty serious pounding with a 4lb sledge on the pickle fork. Actually it all seemed too easy.
  16. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    It'll help alot getting it up on a lift, instead of working on the ground. Plus, being in a 'professional' shop with all sorts of tools really helps also :)
