Finally started it (3 Viewers)
I hate steering columns. They are a bitch to rebuild. Had to add a slip to the column to get rid of some flex in the firewall. Took 2 friggin days! Between parts and and having to machine everything. Its the little things that take so damn much time!
Got the new brake booster mounted up and had to check for clearance so we flexed it up again.
Brake booster and master cylinder cleared by 2 1/2" and the orbital cleared great as well.
Got to get the t case brake mount made up and then got it all mounted up. We had to machine some small spacers to mount to the rear output housing because the flange on it isn't machined flat. Just the mounting spaces for the bolt heads are. Kind of a pain but it worked out good. We will probably dress the mount up a little before we paint it all.
Got the front fenders roughed in today. The existing fender flares were cut way into to make room for the tires at full stuff but we needed to fill in some since we moved the front axle forward and there was no way to make the fender look good without fabbing up some patch panels.
Remains of fender before starting:
Last of the flare being chopped out:
Patch panel being bent up:
Trimmed up:
Formed a little:
Tacked in and stitch welded up:
Some shots of the other side bent up:
And the other side in place:
We still need to trim them up and do the radius as well as adding the tube work underneath for support but it's nice to get them this far in one long afternoon.
I'll just bring .pictures!
White Trash of the Elwood Chapter, TORC4x4.org, Cottonland Cruisers.
We got the front fenders all fitted.
Then I came back into the shop and found Devin doing this:
Guess I pissed him off, he done welded my hood shut.
You need to buy that boy some gloves...
He doesn't need gloves, he can aim the sparks pretty good. At least it seems that way. I always walk away with several burns and burn holes in my clothes while I "hold these so I can tack 'em."
We had a few hours this evening to work on it so we got after the fenders. Had to cut them up higher and get the clearance right at the rear. We then started adding some tube!
Then we cut the front of the fender and part of the hood and got the tube bend put in there:
Filled in the rest of the tube and smoothed the welds and this is what we ended up with:
We still need to weld the skin to the tube.
And this is the front view. Tube will come around the front edge of the hood and tie the fenders together and some sort of grill will get fabbed up!
81 1/2 rear and 83 1/2 front. It will be able to back onto a standard width trailer.
Nice work, Fireman, keep it up! Can't wait to see this beast on the trails!
Holding the floor down.
We'll I blew my knee out at the station last week and am immobile so Devin took advantage of me not being able to help by starting on the new headers. Sent a few teaser pics so I had to load my gimpy ass up and head out there to check it out. Going to be a great solution to the problem of routing the exhaust. Will run under the front of the harmonic and join up with the driver side. Will be ceramic coated back to at least the muffler.View attachment 1255340 View attachment 1255341 View attachment 1255342 View attachment 1255344 View attachment 1255344
