Gentlemen... and women... after maybe 4 years abd 110,000 miles, my 100 is going under the knife this week. Its getting new timing belt, generator, starter and water pump, a new valve cover seal cause its leaking a little bit... The Heater Tee's are getting replaced, the air conditioning stop working so thats getting fixed, even if it is the compressor, the passenger side ac water drip is getting fixed... all the fluids that arent clear... right now its just the power steering fluid that isnt clear... brake and trranny fluid are clear... replacing all drive train lubricants, replacing the shocks, fxing the antenna , changing the headlight to LED's with ballast, re doing the leather on the drivers seat and probably the steering wheel cover...cause I wore the old one out.
All the dings ,scratches and rust coming out and all over paint and clear coat.
It needs a new hitch reciever
Getting a usa spec bt45 and adding at least 2 built in usb ports
It already has a new battery.
Thinking about a led light bar mounter in front of the grill... It seems the roof rack would be 2 noisey and occasionally I use my rack.
Am I missing anything?
I am using it as a family long distance trip hauler, I have a farm and it runs around in the fields and on some pretty rough logging roads.
I am wondering about adjustable shocks, cause while most of the time its not carrying much... there are times when it has 6 or 7 people and all their stuff in it...
I forgot, front brakes are in great shape, brake fluid was clear... getting rear pads, rotors
are fine...
timing belt is cracked, replacing it
are fine...
