The top came off my FJ40 almost ten years ago and I'm slowly reassembling it. The FJ40 is a 5/78 but I know that the fiberglass top was replaced at some point so the visor may not be correct for a '78. There was a very large rubber grommet under the washer nozzle and it was all glued in place without a retaining nut. In the picture, the visor is only sitting on the windshield.
- Does the visor sit absolutely flush against the front of the windshield? (I have the weatherstrip that sits atop the windshield.) You can see in the picture where a PO had glued a large rubber washer under the nozzle and fit the visor over it leaving a slight gap between the windshield and visor.
- Is my visor correct for a 5/78? It looks like the cutout for the washer nozzle is not big enough. I believe I should cut it to match other pictures I've seen and push it flush against the windshield. Is that correct?
- Is the photo from CCOT correct for a '78? It shows no cutout for a washer nozzle.
