Fender (not flare) removal - I have seen it here before (1 Viewer)
96LandcruiserPJ
Norco, CA
I know I have seen it here before, but after reading through a ton of posts, I can't find it again.
I have found all of the connectors, but can not figure out how to get to the one behind the light (not the corner). Do I need to remove the headlight to get to that bolt? If you know where the thread is that showed the bolt locations, that would be good, but right now its that support bracket that's left. I was able to get all of the others.
I don't recall one behind the headlight but there are 2 where the front valance meets the fender. Pretty sure you need the headlight and the front parking light removed to access them.
Don't forget the one under the cowling, the one inside the door jam and the 2 underneath at the back where the fender curves under the body.
Oh and don't forget the bunch in the wheel well connect to the inner fender.
